Ir para o conteúdo principal
Beats Studio3 Wireless Speaker Replacement
O que você precisa
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: passo 1, imagem 1 %32 Beats Studio3 Wireless Speaker Replacement, Ear Pad: passo 1, imagem 2 %32
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: passo 2, imagem 1 %32 Beats Studio3 Wireless Speaker Replacement: passo 2, imagem 2 %32 Beats Studio3 Wireless Speaker Replacement: passo 2, imagem 3 %32
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: passo 3, imagem 1 %32 Beats Studio3 Wireless Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: passo 4, imagem 1 %32 Beats Studio3 Wireless Speaker Replacement: passo 4, imagem 2 %32 Beats Studio3 Wireless Speaker Replacement: passo 4, imagem 3 %32
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: passo 5, imagem 1 %32 Beats Studio3 Wireless Speaker Replacement: passo 5, imagem 2 %32 Beats Studio3 Wireless Speaker Replacement: passo 5, imagem 3 %32
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
Conclusão
Nayeli watts
Membro desde: 03/16/23
474 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 Membro de UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 80
Duração total: 854
