Ir para o conteúdo principal
Beats Studio3 Wireless Hinge Replacement
O que você precisa
  1. Beats Studio3 Wireless Hinge Replacement, Ear Pad: passo 1, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement, Ear Pad: passo 1, imagem 2 %32
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Hinge Replacement: passo 2, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 2, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 2, imagem 3 %32
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Hinge Replacement, Speaker: passo 3, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement, Speaker: passo 3, imagem 2 %32
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Hinge Replacement: passo 4, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 4, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 4, imagem 3 %32
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Hinge Replacement: passo 5, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 5, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 5, imagem 3 %32
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
  6. Beats Studio3 Wireless Hinge Replacement, Battery: passo 6, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement, Battery: passo 6, imagem 2 %32
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
  7. Beats Studio3 Wireless Hinge Replacement: passo 7, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 7, imagem 2 %32
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
  8. Beats Studio3 Wireless Hinge Replacement: passo 8, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 8, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 8, imagem 3 %32
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
  9. Beats Studio3 Wireless Hinge Replacement: passo 9, imagem 1 %32
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  10. Beats Studio3 Wireless Hinge Replacement: passo 10, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 10, imagem 2 %32
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
  11. Beats Studio3 Wireless Hinge Replacement, Hinge: passo 11, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement, Hinge: passo 11, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement, Hinge: passo 11, imagem 3 %32
    • Pull the wire making sure that the blue rubber band is off.
    • Heat the glue holding the wires down with a hair dryer or heat gun until the glue softens.
    • Make sure not to overheat any device part, which could cause damage to the sound.
    • With a pointed nylon spudger, remove the glue.
  12. Beats Studio3 Wireless Hinge Replacement: passo 12, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 12, imagem 2 %32
  13. Beats Studio3 Wireless Hinge Replacement: passo 13, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 13, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 13, imagem 3 %32
    • With a hair dryer or heating gun, heat the glue that is sticking the wires down.
    • Use a nylon spudger to remove the softened glue.
    • Remove the circular tape inside of the ear pad.
  14. Beats Studio3 Wireless Hinge Replacement: passo 14, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 14, imagem 2 %32
    • Remove the single 3.5 mm screw with a Phillips #0 screwdriver.
    • Pull apart the top layer of the earpiece.
  15. Beats Studio3 Wireless Hinge Replacement: passo 15, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 15, imagem 2 %32
    • Remove the tape holding the wires in place.
    • Pull the wires through the hole with your hand.
  16. Beats Studio3 Wireless Hinge Replacement: passo 16, imagem 1 %32
    • Bend the hinge and remove the two 3.5 mm screws with a Phillips #0 screwdriver.
  17. Beats Studio3 Wireless Hinge Replacement: passo 17, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 17, imagem 2 %32 Beats Studio3 Wireless Hinge Replacement: passo 17, imagem 3 %32
    • Pull the hinge down.
    • Pull on the wires one at a time making sure you don't damage them.
  18. Beats Studio3 Wireless Hinge Replacement: passo 18, imagem 1 %32 Beats Studio3 Wireless Hinge Replacement: passo 18, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With tweezers, remove the pin located inside of the hinge.
Conclusão
Uma outra pessoa concluiu este guia.
Nayeli watts
Membro desde: 03/16/23
474 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 Membro de UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 43
Últimos 30 dias: 234
Duração total: 3,544
