Ir para o conteúdo principal
Beats Studio3 Wireless Battery Replacement
O que você precisa
  1. Beats Studio3 Wireless Battery Replacement, Battery: passo 1, imagem 1 %32 Beats Studio3 Wireless Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
    • Be gentle while removing this piece as it is glued on with adhesive.
    Pergunte ao FixBot
    Comentar
  2. Beats Studio3 Wireless Battery Replacement: passo 2, imagem 1 %32 Beats Studio3 Wireless Battery Replacement: passo 2, imagem 2 %32
    • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Beats Studio3 Wireless Battery Replacement: passo 3, imagem 1 %32 Beats Studio3 Wireless Battery Replacement: passo 3, imagem 2 %32 Beats Studio3 Wireless Battery Replacement: passo 3, imagem 3 %32
    • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
    • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
    • The panel will pop open after separating.
    Pergunte ao FixBot
    Comentar
  4. Beats Studio3 Wireless Battery Replacement: passo 4, imagem 1 %32
    • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
    • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
    Pergunte ao FixBot
    Comentar
  5. Beats Studio3 Wireless Battery Replacement: passo 5, imagem 1 %32 Beats Studio3 Wireless Battery Replacement: passo 5, imagem 2 %32
    • Use a nylon spudger to lift up the glue sticking the wires down.
    • Use a nylon spudger to lift the connector to disconnect the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
4Comentários do guia
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Responder Compartilhar
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb - Responder Compartilhar
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Responder Compartilhar
My beats studio 3 proplem was it plink whit when i connect it with the charger, but when i press to start it it blinks full red .
My Qus is .. is the battery are dameged ..?!
Hmam - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 88
Últimos 30 dias: 368
Ao todo: 12,305
