Ir para o conteúdo principal
Beats Studio First Generation Batteries Replacement
O que você precisa
  1. Beats Studio First Generation Batteries Replacement, Identify the Left Speaker Housing: passo 1, imagem 1 %32
    • The left speaker is the speaker that holds the batteries and does not have the power switch.
    Pergunte ao FixBot
    Comentar
  2. Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, imagem 1 %32 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, imagem 2 %32 Beats Studio First Generation Batteries Replacement, Removing the Battery Cap: passo 2, imagem 3 %32
    • Place two fingers on each side of the cap. Press and twist counterclockwise to loosen the cap.
    • Once the cap is loose, simply lift the cap out to reveal the batteries.
    Pergunte ao FixBot
    Comentar
  3. Beats Studio First Generation Batteries Replacement, Batteries!: passo 3, imagem 1 %32
    • Carefully pull the batteries out of their housings. When putting in new batteries, make sure that you place each battery in the correct orientation.
    Pergunte ao FixBot
    Comentar
Conclusão
24 outras pessoas executaram este guia.
Oscar
Membro desde: 04/15/14
1.216 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-18, Regan Spring 2014 Membro de Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 Membros
Autoria de 13 guias
29Comentários do guia
hi man you post is help me a lot thank you..God bless you
EL TIO SAM MARS - Responder Compartilhar
Are u using 4A batteries on this? Please reply ASAP. The 3a batteries won't fit on my beats wireless studio.
Nessa Upzs - Responder Compartilhar
They are 2 x AAA batteries. This is Beats Studio first generation which are WIRED headphones.
John Coops - Responder Compartilhar
Help,I'm trying to twist off battery compartment and it's not budging! Should I try and pry off w/screwdriver! Any ideas?
Kathy - Responder Compartilhar
hello jus curious if u got the cap to come off n how if so? any advice wld b greatly appreciated please n thank u
Randi - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 27
Últimos 30 dias: 182
Ao todo: 153,663
