Ir para o conteúdo principal
Beats Studio 2 Wireless Battery Replacement
O que você precisa
  1. Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, imagem 1 %32 Beats Studio 2 Wireless Battery Replacement, Battery: passo 1, imagem 2 %32
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: passo 2, imagem 1 %32 Beats Studio 2 Wireless Battery Replacement: passo 2, imagem 2 %32
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: passo 3, imagem 1 %32
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: passo 4, imagem 1 %32
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: passo 5, imagem 1 %32 Beats Studio 2 Wireless Battery Replacement: passo 5, imagem 2 %32 Beats Studio 2 Wireless Battery Replacement: passo 5, imagem 3 %32
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
Conclusão
Jack Wilson
Membro desde: 03/20/23
494 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-3, Ramos Spring 2023 Membro de UMass Dartmouth, Team 5-3, Ramos Spring 2023
UMASSD-RAMOS-S23S5G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 146
Duração total: 2,396
