Ir para o conteúdo principal
Beats Solo 3 Charging Port Replacement
O que você precisa
  1. Beats Solo 3 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32
    • Use a nylon or metal spudger to carefully remove the ear pad from the right ear cup.
    • Be careful to not rip the ear pad fabric with your tools.
  2. Beats Solo 3 Charging Port Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the seven screws that hold the speaker in place.
    • There are two screws in the big red circle at the bottom.
  3. Beats Solo 3 Charging Port Replacement: passo 3, imagem 1 %32
    • Desolder all wires connecting the circuit panel to the rest of the device.
    • There are two wires in the big red circle at the bottom and one in the small red circle above.
  4. Beats Solo 3 Charging Port Replacement: passo 4, imagem 1 %32 Beats Solo 3 Charging Port Replacement: passo 4, imagem 2 %32
    • After you desolder all wires you are able to remove and replace the charging port.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 34
Últimos 30 dias: 158
Duração total: 5,098
