Ir para o conteúdo principal
Beats Solo 3 Battery Replacement
O que você precisa
  1. Beats Solo 3 Battery Replacement, Battery: passo 1, imagem 1 %32 Beats Solo 3 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Pry off the outside pane on the right side of the headphone with an opening tool.
  2. Beats Solo 3 Battery Replacement: passo 2, imagem 1 %32
    • You should see your battery here. It will be square with yellow packaging.
    • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
  3. Beats Solo 3 Battery Replacement: passo 3, imagem 1 %32 Beats Solo 3 Battery Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Grasp the battery's small bundled connector, and pull gently to remove.
    • Carefully remove the top attachment from the headphones with tweezers or your fingers.
  4. Beats Solo 3 Battery Replacement: passo 4, imagem 1 %32 Beats Solo 3 Battery Replacement: passo 4, imagem 2 %32
    • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
    • Do not bend or puncture the lithium-ion battery.
    • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
    • If it is, then place it back where it belongs in the headphones.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Where too buy battery?
GSD - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 128
Últimos 30 dias: 593
Duração total: 12,765
