Introdução
This is a battery replacement guide for Beats Solo3. The model number is A1796. This guide will show you how to correctly remove and replace the battery for your headphones. For this guide you will need a pry or opening tool and an optional pair of tweezers. The battery for the headphones is the UltraLast Lithium-Polymer battery. The battery powers the headphones. Symptoms which can result in a battery replacement can be found on our troubleshooting page.
O que você precisa
Pry off the outside pane on the right side of the headphone with an opening tool.
3 outras pessoas executaram este guia.
