Ir para o conteúdo principal
Beats Pill 1.0 Battery Replacement
O que você precisa
  1. Beats Pill 1.0 Battery Replacement, Removing the Case Screws: passo 1, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: passo 1, imagem 2 %32 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: passo 1, imagem 3 %32
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
    I bought a brand new Beats Pill 1.0 online last week the first night it seemed to work all right the next day I charged it I plugged it in and it was crackling on the left hand side from the front and now the whole volume of both sides very low but it is still getting a Bluetooth connectivity I tried to reset it by holding the baby and the power button to get this thing in the back to flag it would not reset that way any suggestions I meant it is for a lot of money I paid $170 I thought I was getting a brand new device
    Steven Sudnick - Responder
  2. Beats Pill 1.0 Battery Replacement, Removing Center Cover: passo 2, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Removing Center Cover: passo 2, imagem 2 %32 Beats Pill 1.0 Battery Replacement, Removing Center Cover: passo 2, imagem 3 %32
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Beats Pill 1.0 Battery Replacement, Separate the Device: passo 3, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Separate the Device: passo 3, imagem 2 %32 Beats Pill 1.0 Battery Replacement, Separate the Device: passo 3, imagem 3 %32
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: passo 4, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: passo 4, imagem 2 %32
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: passo 5, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: passo 5, imagem 2 %32
    • Carefully remove the black and red NFC sensor wires.
  6. Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: passo 6, imagem 1 %32 Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: passo 6, imagem 2 %32
    • Carefully remove the control cables (4 black, 1 red).
  7. Beats Pill 1.0 Battery Replacement, Battery: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Phillips #0 Screwdriver
    $5.49
    Comprar
  8. Beats Pill 1.0 Battery Replacement, Remove motherboard screws: passo 8, imagem 1 %32
    $5.49
    Comprar
    • Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
  9. Beats Pill 1.0 Battery Replacement, Remove the motherboard: passo 9, imagem 1 %32
    Comprar
    • Gently remove the motherboard from the case
    • Remove the yellow NFC module with Tweezers
    Is this two batteries we need to replace? Or is just the right one the battery?
    delliskd - Responder
    The batteries I bought from Amazon came with two batteries alreaded connected to one another. One one set of leads needs to be soldered
    Scott Carpenter - Responder
    Where is the yellow NFC module in the photo? I do not think there is a picture of it removed.
    salcampana - Responder
    You see a part of it on Photoshop step 7, on the top, it’s stuck behind the motherboard screws, just lift it loose with a tweezer or something, it could be a little bit ‘glued’/fixed to its surroundings. After battery change, just put it back, does not need any fixation.
    lofors -
  10. Beats Pill 1.0 Battery Replacement, Remove the power button: passo 10, imagem 1 %32
    • Remove power button and springs.
  11. Beats Pill 1.0 Battery Replacement, Cut off battery: passo 11, imagem 1 %32
    • Cut off the battery wires
  12. Beats Pill 1.0 Battery Replacement, Attach new battery: passo 12, imagem 1 %32
    • Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
Conclusão
28 outras pessoas executaram este guia.
Paul Haas
Membro desde: 01/13/15
778 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-2, Hickman Winter 2015 Membro de USF Tampa, Team 3-2, Hickman Winter 2015
USFT-HICKMAN-W15S3G2
Membros da 4
Autoria de 6 guias
10 comentários
donde puedo comprar la batttery para pill beats
felix - Responder
Where can you buy the replacement battery
wtmcclure - Responder
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
jmestascatcoparco - Responder
Looks like the Bluetooth antenna
James Jenkins -
It is the NFC module
bobapunk -
Are there two batteries in this thing, or is the left black box a different part?
hello, my dear friend, we have remplacement battery for Beat Pill 2.0. are you interested in introducing it? feel free to contact me.
kevin zhang - Responder
I bought a cheap speaker for no where near the price of what the pill cost me. The battery never runs out! I have had it for years! The pill on the other hand I have changed one already and does not even turn on! Beats should be ashamed for charging what they do for such a poor product with a expensive price tag! And now I’m expected to open it up myself and change the battery! I feel completely mugged off by BEATS. You know that saying about the more expensive the better the product? It’s a 100% lies! Don’t be fooled by a label! Most of the things you purchase are made in China or India and sent to another country where they are stamped and claim it’s made in that county. Wake up people !
Alex - Responder
Oh man 🙈 kann ich die auch einfach zu euch einsenden? 😂
Irina W - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 81
Últimos 30 dias: 382
Duração total: 145,166
