Ir para o conteúdo principal
Bear 1000 Power Entry Module Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: passo 1, imagem 1 %32
    • Remove the ribbon cable at the connection on the oxygen blender control board.
    Pergunte ao FixBot
    Comentar
  2. Bear 1000 Power Entry Module Replacement: passo 2, imagem 1 %32
    • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
    Pergunte ao FixBot
    Comentar
  3. Bear 1000 Power Entry Module Replacement: passo 3, imagem 1 %32
    • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
    Pergunte ao FixBot
    Comentar
  4. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: passo 4, imagem 1 %32
    • Remove the pneumatic and electrical connections labeled.
    Pergunte ao FixBot
    Comentar
    • Remove the water trap bowls on the rear of the unit.
    Pergunte ao FixBot
    Comentar
  5. Bear 1000 Power Entry Module Replacement: passo 6, imagem 1 %32
    • Remove the four screws and remove the manifold.
    Pergunte ao FixBot
    Comentar
    • Remove the two screws holding the power supply to the manifold.
    Pergunte ao FixBot
    Comentar
    • Mark or label the 6 faston connections as to position and remove
    Pergunte ao FixBot
    Comentar
    • Mark or label the two wires going to the power switch and remove at the power switch end
    Pergunte ao FixBot
    Comentar
    • Using an allen wrench, remove the power cord retaining bracket.
    Pergunte ao FixBot
    Comentar
  6. Bear 1000 Power Entry Module Replacement: passo 11, imagem 1 %32
    • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
    Pergunte ao FixBot
    Comentar
    • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
    Pergunte ao FixBot
    Comentar
    • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
    Pergunte ao FixBot
    Comentar
    • Transfer the voltage selector drum from the original module to the replacement and reinstall.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Eli Ferman
Membro desde: 04/08/20
607 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S7-G12, Paton Fall 2020 Membro de Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 260
