Ir para o conteúdo principal
Nextbook Premium 7SE Battery Replacement
O que você precisa
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 1 %32 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 2 %32 Nextbook Premium 7SE Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: passo 2, imagem 1 %32
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: passo 4, imagem 1 %32 Nextbook Premium 7SE Battery Replacement: passo 4, imagem 2 %32 Nextbook Premium 7SE Battery Replacement: passo 4, imagem 3 %32
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: passo 5, imagem 1 %32 Nextbook Premium 7SE Battery Replacement: passo 5, imagem 2 %32 Nextbook Premium 7SE Battery Replacement: passo 5, imagem 3 %32
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Como soldar e dessoldar contatos
    • Use caution when operating the soldering iron.
Conclusão
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Uma outra pessoa concluiu este guia.
Walker Karstens
Membro desde: 10/30/16
364 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 4-1, Williams Fall 2016 Membro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 828
