Ir para o conteúdo principal
Zenbre SoundBank Z3 Battery Replacement
O que você precisa
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: passo 2, imagem 1 %32
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: passo 3, imagem 1 %32 Zenbre SoundBank Z3 Battery Replacement: passo 3, imagem 2 %32
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: passo 4, imagem 1 %32 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: passo 4, imagem 2 %32 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: passo 4, imagem 3 %32
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: passo 5, imagem 1 %32 Zenbre SoundBank Z3 Battery Replacement, Battery: passo 5, imagem 2 %32
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: passo 6, imagem 1 %32 Zenbre SoundBank Z3 Battery Replacement: passo 6, imagem 2 %32
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: passo 7, imagem 1 %32
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
    where do es one find replacement battery. size, voltage, etc??
    tfilm@sbcglobal.net - Responder
Conclusão
3 outras pessoas executaram este guia.
Cherian Thomas
Membro desde: 03/25/16
334 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
Membros da 5
Autoria de 8 guias
3 comentários
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - Responder
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 4,575
