Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide provides a step by step comprehensive method for the removal of the battery from the speaker. Unfortunately, the battery is soldered into the motherboard via wires, therefore this replacement guide will be a bit more difficult than a normal battery replacement guide.
Peças
Nenhum componente especificado.
  1. Power off  the SoundBank Z3. Flip over the device.
    • Power off the SoundBank Z3.
    • Flip over the device.
    • Remove the silicon feet by peeling them up.
    • The feet can be reapplied without extra adhesive, but only if you are careful not to let the sticky side touch anything.
  2. Remove the eight 11 mm Philips screws from the bottom of the device.
    • Remove the eight 11 mm Philips screws from the bottom of the device.
  3. Using a plastic opening tool, remove the bottom panel. Using a plastic opening tool, remove the bottom panel.
    • Using a plastic opening tool, remove the bottom panel.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard. Remove the plastic panel. Remove the plastic panel.
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  6. Remove the battery from the holder. When doing it for the first time, it may be difficult. I suggest using a thin sturdy tool, to get in between the battery and the speaker wall, this will let you wiggle the battery free from its surrounding.
    • Remove the battery from the holder. When doing it for the first time, it may be difficult.
    • I suggest using a thin sturdy tool, to get in between the battery and the speaker wall, this will let you wiggle the battery free from its surrounding.
    • You might find it easier to remove it by hand.
    • If the battery is punctured, leaking or bloated/puffy at all leave it alone, It may be hazardous to handle and instead should be properly disposed.
  7. The foam is just pressured fit into the slot and can be removed by hand. Remove the foam around the wires. This can be done by unraveling  the foam.
    • The foam is just pressured fit into the slot and can be removed by hand.
    • Remove the foam around the wires. This can be done by unraveling the foam.
    • The foam can be re-wrapped, as with the feet from earlier, care must be taken if you wish to reapply it.
  8. These are the leads that must be removed to separate the battery from the mother board.
    • These are the leads that must be removed to separate the battery from the mother board.
    • Follow this guide to help you remove the wires from the mother board.
Conclusão
3 outras pessoas concluíram este guia.
Cherian Thomas
Membro desde: 25/03/2016
334 Reputação
5 Guias de autoria
Equipe
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - Responder
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 4,217
