Ir para o conteúdo principal
Battery Disconnect
O que você precisa
  1. Battery Disconnect, SIM Card: passo 1, imagem 1 %32 Battery Disconnect, SIM Card: passo 1, imagem 2 %32
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    Pergunte ao FixBot
    Comentar
  2. Battery Disconnect: passo 2, imagem 1 %32 Battery Disconnect: passo 2, imagem 2 %32
    • Remove the SIM card tray from the phone.
    • The SIM card(s) and SD card will fall out of the tray easily.
    • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
    • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
    Pergunte ao FixBot
    Comentar
  3. Battery Disconnect, Back Cover: passo 3, imagem 1 %32
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
    Pergunte ao FixBot
    Comentar
  4. Battery Disconnect: passo 4, imagem 1 %32
    • Slide the opening pick to the bottom left corner to release the clips.
    Pergunte ao FixBot
    Comentar
  5. Battery Disconnect: passo 5, imagem 1 %32
    • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
    Pergunte ao FixBot
    Comentar
  6. Battery Disconnect: passo 6, imagem 1 %32
    • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
    Pergunte ao FixBot
    Comentar
  7. Battery Disconnect: passo 7, imagem 1 %32
    • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
    Pergunte ao FixBot
    Comentar
  8. Battery Disconnect: passo 8, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  9. Battery Disconnect, Motherboard Cover: passo 9, imagem 1 %32
    • Remove screws from the motherboard antenna cover.
    • 3 Phillips #00, 3mm length.
    Pergunte ao FixBot
    Comentar
  10. Battery Disconnect: passo 10, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tip of a spudger or tweezers to remove the antenna cover.
    Pergunte ao FixBot
    Comentar
  11. Battery Disconnect: passo 11, imagem 1 %32
    • Remove screws from the motherboard cover.
    Pergunte ao FixBot
    Comentar
  12. Battery Disconnect: passo 12, imagem 1 %32
    • Use the tip of a spudger or tweezers to remove the motherboard cover.
    Pergunte ao FixBot
    Comentar
  13. Battery Disconnect, Battery Disconnect: passo 13, imagem 1 %32 Battery Disconnect, Battery Disconnect: passo 13, imagem 2 %32
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    Pergunte ao FixBot
    Comentar
  14. Battery Disconnect: passo 14, imagem 1 %32
    • Gently flex the battery connector away from its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Thomas Boland
Membro desde: 09/29/20
1.932 Reputação
Autoria de 5 guias
2Comentários do guia
Do I need to heat up the screen of my phone to make it easier for me to get the back cover off of my phone?
Pifase - Responder Compartilhar
no, it just clips on, there's no adhesive
Ely Wickander - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 60
Ao todo: 3,149
