Ir para o conteúdo principal
Basis Peak Frame Replacement
O que você precisa
    1. Basis Peak Frame Replacement, Frame: passo 1, imagem 1 %32
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      Pergunte ao FixBot
      Comentar
    2. Basis Peak Frame Replacement: passo 2, imagem 1 %32 Basis Peak Frame Replacement: passo 2, imagem 2 %32
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      Pergunte ao FixBot
      Comentar
    3. Basis Peak Frame Replacement: passo 3, imagem 1 %32
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      Pergunte ao FixBot
      Comentar
    4. Basis Peak Frame Replacement: passo 4, imagem 1 %32
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 444
