Ir para o conteúdo principal
Basic Maintenance
O que você precisa
  1. Basic Maintenance, Locating the side panel: passo 1, imagem 1 %32 Basic Maintenance, Locating the side panel: passo 1, imagem 2 %32
    • First, locate the side panel on the far left side of your board.
    • Then, flip your board upside down.
    • Make sure your console is resting on a towel or soft surface, as hard jolts or bumps can cause damage to your board.
    Pergunte ao FixBot
    Comentar
  2. Basic Maintenance, Removing the bracket: passo 2, imagem 1 %32 Basic Maintenance, Removing the bracket: passo 2, imagem 2 %32
    • Now, use your Phillips-head screwdriver to unscrew the two screws holding the bracket on.
    • Then flip your board over and do the same on the other side to remove the second bracket.
    Pergunte ao FixBot
    Comentar
  3. Basic Maintenance, Loosening the panel screws: passo 3, imagem 1 %32
    • Now, locate the three screws at the bottom of the back panel and loosen them approximately two full turns.
    • Make sure to keep screws separate! Always label and separate different screws to avoid confusion when we reassemble the board.
    Pergunte ao FixBot
    Comentar
  4. Basic Maintenance, Remove the metal pieces: passo 4, imagem 1 %32
    • Now flip your board over again so it is right-side-up.
    • Then, remove the seven screws holding the metal piece on with the same screwdriver. There is one screw to the far right of the piece that I could not fit into the photo.
    Pergunte ao FixBot
    Comentar
  5. Basic Maintenance, Pull the top off: passo 5, imagem 1 %32 Basic Maintenance, Pull the top off: passo 5, imagem 2 %32
    • Now, put your hand on the back of the board and lift up and away from the base of the console. Be careful of any wires!
    • Set the top panel next to the base to avoid wires getting tangled and broken.
    Pergunte ao FixBot
    Comentar
  6. Basic Maintenance, The inside components: passo 6, imagem 1 %32 Basic Maintenance, The inside components: passo 6, imagem 2 %32
    • You might notice that a lot of the components inside the lighting board look similar to those of a desktop computer. The power supply, hard drive, RAM, CPU, and cooling system are all in the base of the board.
    • If you have a compressed air can or blower, use that to clean the main components, especially around the CPU and heatsinks, as these can get clogged with dust and debris. If you don't have one of these tools, use a DRY paper towel or tissue to gently wipe down the components.
    Pergunte ao FixBot
    Comentar
  7. Basic Maintenance, Re-seating the RAM: passo 7, imagem 1 %32 Basic Maintenance, Re-seating the RAM: passo 7, imagem 2 %32
    • RAM is good to re-seat every so often, as it helps to maintain clean ports and fast memory speeds.
    • To remove the RAM, press down on the two clips on either side of the stick, then pull up on the RAM to remove it.
    • Once you remove it, you can take your air blower and gently blow off any dust on the connectors and memory cards.
    Pergunte ao FixBot
    Comentar
    • Now reverse these steps to reassemble your ETC Ion 1000!
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
someperson
Membro desde: 02/11/26
953 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 88
