Introdução
This guide will show you how to remove the base cover of your Alienware 17 R4. Removing the base cover is necessary to access the device's interior.
O que você precisa
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Uma outra pessoa concluiu este guia.
