Ir para o conteúdo principal
Backpack Plastic Buckle Replacement
O que você precisa
    1. Backpack Plastic Buckle Replacement, Your buckle breaks but you do not want to take out the stitching to replace it: passo 1, imagem 1 %32
      • The female side is often sewn in. This makes replacement very difficult. Many packs are discarded for this reason
      Pergunte ao FixBot
      Comentar
    2. Backpack Plastic Buckle Replacement, The male side (side with prongs) is easy to replace: passo 2, imagem 1 %32
      • Slide the old one off the strap and install the new male side. If the belt slips through the new male side too easily, remove it and flip it over before reinstalling it.
      Pergunte ao FixBot
      Comentar
    3. Backpack Plastic Buckle Replacement, Install the new female side of the buckle: passo 3, imagem 1 %32
      • Cut the original plastic buckle off the belt, take the stainless steel rod out of the new buckle, thread it through the belt and tighten
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 50
Ao todo: 754
