Ir para o conteúdo principal
Backbone One Right Mainboard Replacement
O que você precisa
    1. Backbone One Right Mainboard Replacement, Remove the screws: passo 1, imagem 1 %32
      • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
      Pergunte ao FixBot
      Comentar
    2. Backbone One Right Mainboard Replacement, Rotate the upper part: passo 2, imagem 1 %32 Backbone One Right Mainboard Replacement, Rotate the upper part: passo 2, imagem 2 %32 Backbone One Right Mainboard Replacement, Rotate the upper part: passo 2, imagem 3 %32
      • Lift up the upper cover of the controller.
      • Swing the upper cover over and place it on the controller case.
      • Make sure that the interconnecting cable has no tension.
      Pergunte ao FixBot
      Comentar
    1. Backbone One Right Mainboard Replacement, Remove the protective tape: passo 3, imagem 1 %32 Backbone One Right Mainboard Replacement, Remove the protective tape: passo 3, imagem 2 %32 Backbone One Right Mainboard Replacement, Remove the protective tape: passo 3, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
      Pergunte ao FixBot
      Comentar
    2. Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 1 %32 Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 2 %32 Backbone One Right Mainboard Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 3 %32
      • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
      Pergunte ao FixBot
      Comentar
    3. Backbone One Right Mainboard Replacement, Disconnect the interconnect cable: passo 5, imagem 1 %32 Backbone One Right Mainboard Replacement, Disconnect the interconnect cable: passo 5, imagem 2 %32
      • Disconnect the cable by pulling it straight out the ZIF connector.
      Pergunte ao FixBot
      Comentar
    4. Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: passo 6, imagem 1 %32 Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: passo 6, imagem 2 %32 Backbone One Right Mainboard Replacement, Disconnect the phone connector cables: passo 6, imagem 3 %32
      • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
      Pergunte ao FixBot
      Comentar
    5. Backbone One Right Mainboard Replacement, Separate the upper case: passo 7, imagem 1 %32
      • Separate the the upper case of the left controller handle.
      Pergunte ao FixBot
      Comentar
    6. Backbone One Right Mainboard Replacement, Remove the screws: passo 8, imagem 1 %32
      • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
      Pergunte ao FixBot
      Comentar
    7. Backbone One Right Mainboard Replacement, Remove the trigger: passo 9, imagem 1 %32 Backbone One Right Mainboard Replacement, Remove the trigger: passo 9, imagem 2 %32
      • Remove the trigger.
      Pergunte ao FixBot
      Comentar
    1. Backbone One Right Mainboard Replacement, Remove the bumper: passo 10, imagem 1 %32 Backbone One Right Mainboard Replacement, Remove the bumper: passo 10, imagem 2 %32
      • Remove the bumper.
      Pergunte ao FixBot
      Comentar
    1. Backbone One Right Mainboard Replacement, Remove the screws: passo 11, imagem 1 %32
      • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
      Pergunte ao FixBot
      Comentar
    2. Backbone One Right Mainboard Replacement, Remove the mainboard: passo 12, imagem 1 %32 Backbone One Right Mainboard Replacement, Remove the mainboard: passo 12, imagem 2 %32 Backbone One Right Mainboard Replacement, Remove the mainboard: passo 12, imagem 3 %32
      • Remove the mainboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Adriana Zwink
Membro desde: 12/18/19
68.008 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 48.766 guias
1Comentário do guia
Where do I find this replacement part?
pete_r10@live.com - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 30
Ao todo: 2,113
