Ir para o conteúdo principal
Backbone One Left Bumper Replacement
O que você precisa
  1. Backbone One Left Bumper Replacement, Unfasten the screws: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Pergunte ao FixBot
  2. Backbone One Left Bumper Replacement, Rotate the upper cover: passo 2, imagem 1 %32 Backbone One Left Bumper Replacement, Rotate the upper cover: passo 2, imagem 2 %32 Backbone One Left Bumper Replacement, Rotate the upper cover: passo 2, imagem 3 %32
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Pergunte ao FixBot
  3. Backbone One Left Bumper Replacement, Remove the protective tape: passo 3, imagem 1 %32 Backbone One Left Bumper Replacement, Remove the protective tape: passo 3, imagem 2 %32 Backbone One Left Bumper Replacement, Remove the protective tape: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Pergunte ao FixBot
  4. Backbone One Left Bumper Replacement, Open the ZIF connector: passo 4, imagem 1 %32 Backbone One Left Bumper Replacement, Open the ZIF connector: passo 4, imagem 2 %32
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Pergunte ao FixBot
  5. Backbone One Left Bumper Replacement, Disconnect the interconnect cable: passo 5, imagem 1 %32 Backbone One Left Bumper Replacement, Disconnect the interconnect cable: passo 5, imagem 2 %32
    • Use your fingers to disconnect the interconnect cable from its connector.
    Pergunte ao FixBot
  6. Backbone One Left Bumper Replacement: passo 6, imagem 1 %32 Backbone One Left Bumper Replacement: passo 6, imagem 2 %32
    • Remove the upper half of the left controller assembly.
    Pergunte ao FixBot
  7. Backbone One Left Bumper Replacement, Remove the screw: passo 7, imagem 1 %32 Backbone One Left Bumper Replacement, Remove the screw: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    Pergunte ao FixBot
  8. Backbone One Left Bumper Replacement, Remove the trigger: passo 8, imagem 1 %32 Backbone One Left Bumper Replacement, Remove the trigger: passo 8, imagem 2 %32
    • Remove the left trigger.
    Pergunte ao FixBot
  9. Backbone One Left Bumper Replacement, Remove the bumper: passo 9, imagem 1 %32 Backbone One Left Bumper Replacement, Remove the bumper: passo 9, imagem 2 %32
    • Use your fingers to remove the left bumper.
    Pergunte ao FixBot
Conclusão
Adriana Zwink
Membro desde: 12/18/19
66.798 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.713 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 56
Ao todo: 1,339
