Ir para o conteúdo principal
Backbone One Face Buttons Replacement
O que você precisa
  1. Backbone One Face Buttons Replacement, Remove the screws: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Pergunte ao FixBot
    Comentar
  2. Backbone One Face Buttons Replacement, Rotate the upper part: passo 2, imagem 1 %32 Backbone One Face Buttons Replacement, Rotate the upper part: passo 2, imagem 2 %32 Backbone One Face Buttons Replacement, Rotate the upper part: passo 2, imagem 3 %32
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    Pergunte ao FixBot
    Comentar
  3. Backbone One Face Buttons Replacement, Remove the protective tape: passo 3, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the protective tape: passo 3, imagem 2 %32 Backbone One Face Buttons Replacement, Remove the protective tape: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
    Pergunte ao FixBot
    Comentar
  4. Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 1 %32 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 2 %32 Backbone One Face Buttons Replacement, Open the interconnect cable ZIF connector: passo 4, imagem 3 %32
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
    Pergunte ao FixBot
    Comentar
  5. Backbone One Face Buttons Replacement, Disconnect the interconnect cable: passo 5, imagem 1 %32 Backbone One Face Buttons Replacement, Disconnect the interconnect cable: passo 5, imagem 2 %32
    • Disconnect the cable by pulling it straight out the ZIF connector.
    Pergunte ao FixBot
    Comentar
  6. Backbone One Face Buttons Replacement, Disconnect the phone connector cables: passo 6, imagem 1 %32 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: passo 6, imagem 2 %32 Backbone One Face Buttons Replacement, Disconnect the phone connector cables: passo 6, imagem 3 %32
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
    Pergunte ao FixBot
    Comentar
  7. Backbone One Face Buttons Replacement, Separate the upper case: passo 7, imagem 1 %32
    • Separate the the upper case of the left controller handle.
    Pergunte ao FixBot
    Comentar
  8. Backbone One Face Buttons Replacement, Remove the screws: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
    Pergunte ao FixBot
    Comentar
  9. Backbone One Face Buttons Replacement, Remove the trigger: passo 9, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the trigger: passo 9, imagem 2 %32
    • Remove the trigger.
    Pergunte ao FixBot
    Comentar
  10. Backbone One Face Buttons Replacement, Remove the bumper: passo 10, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the bumper: passo 10, imagem 2 %32
    • Remove the bumper.
    Pergunte ao FixBot
    Comentar
  11. Backbone One Face Buttons Replacement, Remove the screws: passo 11, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
    Pergunte ao FixBot
    Comentar
  12. Backbone One Face Buttons Replacement, Remove the mainboard: passo 12, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the mainboard: passo 12, imagem 2 %32 Backbone One Face Buttons Replacement, Remove the mainboard: passo 12, imagem 3 %32
    • Remove the mainboard.
    Pergunte ao FixBot
    Comentar
  13. Backbone One Face Buttons Replacement, Remove the rubber cover: passo 13, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the rubber cover: passo 13, imagem 2 %32 Backbone One Face Buttons Replacement, Remove the rubber cover: passo 13, imagem 3 %32
    • Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
    Pergunte ao FixBot
    Comentar
  14. Backbone One Face Buttons Replacement, Remove the face buttons: passo 14, imagem 1 %32 Backbone One Face Buttons Replacement, Remove the face buttons: passo 14, imagem 2 %32 Backbone One Face Buttons Replacement, Remove the face buttons: passo 14, imagem 3 %32
    • Use a pair of tweezers to remove the face buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Adriana Zwink
Membro desde: 12/18/19
67.401 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.514 guias
1Comentário do guia
is there any way to do this without taking apart the entire controller?
Robert - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 67
Ao todo: 3,449
