Ir para o conteúdo principal
Backbone One Direction Pad Replacement
O que você precisa
  1. Backbone One Direction Pad Replacement, Unfasten the screws: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Pergunte ao FixBot
    Comentar
  2. Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, imagem 1 %32 Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, imagem 2 %32 Backbone One Direction Pad Replacement, Rotate the upper cover: passo 2, imagem 3 %32
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Pergunte ao FixBot
    Comentar
  3. Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, imagem 2 %32 Backbone One Direction Pad Replacement, Remove the protective tape: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Pergunte ao FixBot
    Comentar
  4. Backbone One Direction Pad Replacement, Open the ZIF connector: passo 4, imagem 1 %32 Backbone One Direction Pad Replacement, Open the ZIF connector: passo 4, imagem 2 %32
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Pergunte ao FixBot
    Comentar
  5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: passo 5, imagem 1 %32 Backbone One Direction Pad Replacement, Disconnect the interconnect cable: passo 5, imagem 2 %32
    • Use your fingers to disconnect the interconnect cable from its connector.
    Pergunte ao FixBot
    Comentar
  6. Backbone One Direction Pad Replacement: passo 6, imagem 1 %32 Backbone One Direction Pad Replacement: passo 6, imagem 2 %32
    • Remove the upper half of the left controller assembly.
    Pergunte ao FixBot
    Comentar
  7. Backbone One Direction Pad Replacement, Remove the screw: passo 7, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the screw: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    Pergunte ao FixBot
    Comentar
  8. Backbone One Direction Pad Replacement, Remove the trigger: passo 8, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the trigger: passo 8, imagem 2 %32
    • Remove the left trigger.
    Pergunte ao FixBot
    Comentar
  9. Backbone One Direction Pad Replacement, Remove the bumper: passo 9, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the bumper: passo 9, imagem 2 %32
    • Use your fingers to remove the left bumper.
    Pergunte ao FixBot
    Comentar
  10. Backbone One Direction Pad Replacement, Remove the screws: passo 10, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
    Pergunte ao FixBot
    Comentar
  11. Backbone One Direction Pad Replacement, Remove the mainboard: passo 11, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the mainboard: passo 11, imagem 2 %32
    • Remove the mainboard.
    Pergunte ao FixBot
    Comentar
  12. Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, imagem 1 %32 Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, imagem 2 %32 Backbone One Direction Pad Replacement, Remove the direction pad: passo 12, imagem 3 %32
    • Use a pair of blunt nose tweezers to remove the direction pad.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
Membro desde: 12/18/19
67.401 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.514 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 99
Ao todo: 3,214
