Introdução
In this guide it teaches how to remove the back panel of the laptop. You will need a screwdriver and a opening tool to complete this task.
O que você precisa
Flip the laptop so that the back is facing upwards.
Locate the small screw on the back that holds the "L" shaped panel.
Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
