Ir para o conteúdo principal
BOSE SoundTouch 30 Motherboard Replacement
O que você precisa
  1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: passo 1, imagem 1 %32 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: passo 1, imagem 2 %32
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    Pergunte ao FixBot
    Comentar
  2. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: passo 2, imagem 1 %32
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
    Pergunte ao FixBot
    Comentar
  3. BOSE SoundTouch 30 Motherboard Replacement: passo 3, imagem 1 %32 BOSE SoundTouch 30 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Pergunte ao FixBot
    Comentar
  4. BOSE SoundTouch 30 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    Pergunte ao FixBot
    Comentar
  5. BOSE SoundTouch 30 Motherboard Replacement: passo 5, imagem 1 %32 BOSE SoundTouch 30 Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    Pergunte ao FixBot
    Comentar
  6. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Brennen Irey
Membro desde: 04/18/18
1.269 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S16-G2, Livingston Spring 2018 Membro de Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Membros
Autoria de 8 guias
5Comentários do guia
Where do I can get the power supply?
Ulises Peña - Responder Compartilhar
where can i get the notherboard? 354437-0060
guillermo gibson - Responder Compartilhar
Please where can I get the motherboard
Marjorie Newell - Responder Compartilhar
Where can I get the motherboard?
Bryan Lozano - Responder Compartilhar
I am getting an error “Error code 0000. Contact Bose service” what do I do?
Ashley Murray - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 70
Ao todo: 7,630
