Ir para o conteúdo principal
BMS Replacement Replacement
  1. BMS Replacement Replacement, Set up: passo 1, imagem 1 %32
    • Start with a clean work bench
    • Remove all conductive a tools from your work bench
    • Wear safety glasses
    Pergunte ao FixBot
    Comentar
  2. BMS Replacement Replacement, Open the case: passo 2, imagem 1 %32 BMS Replacement Replacement, Open the case: passo 2, imagem 2 %32 BMS Replacement Replacement, Open the case: passo 2, imagem 3 %32
    • Use a stanley knife to cut though the sealant of the battery case
    • Use caution when doing this
    Pergunte ao FixBot
    Comentar
  3. BMS Replacement Replacement, Start opening the case: passo 3, imagem 1 %32 BMS Replacement Replacement, Start opening the case: passo 3, imagem 2 %32
    • Slowly lever the case apart.
    • Start at the bottom and work your way around to the handle
    Pergunte ao FixBot
    Comentar
  4. BMS Replacement Replacement, Completely open the case: passo 4, imagem 1 %32 BMS Replacement Replacement, Completely open the case: passo 4, imagem 2 %32 BMS Replacement Replacement, Completely open the case: passo 4, imagem 3 %32
    • Fully open the case
    • The glue is quite strong, use you hand inside to seperate the case from the heat shrink
    • Be careful to not damage the delicate switch wires
    Pergunte ao FixBot
    Comentar
  5. BMS Replacement Replacement, Removing the battery pack: passo 5, imagem 1 %32 BMS Replacement Replacement, Removing the battery pack: passo 5, imagem 2 %32 BMS Replacement Replacement, Removing the battery pack: passo 5, imagem 3 %32
    • Cut off the thick black shrink wrap
    • The main power cables and switch remain connected to the top cover.
    • Gently release and remove the switch cables from any adhesive so that they are not under stain when opening the case.
    • Rest the top cover on a box or similar to prevent staining the cables
    Pergunte ao FixBot
    Comentar
  6. BMS Replacement Replacement, Remove heat shrink: passo 6, imagem 1 %32 BMS Replacement Replacement, Remove heat shrink: passo 6, imagem 2 %32 BMS Replacement Replacement, Remove heat shrink: passo 6, imagem 3 %32
    • Remove the heat shrink from the battery pack.
    • go slowly at the cable end as to not break or stain any thinn switch cables
    Pergunte ao FixBot
    Comentar
  7. BMS Replacement Replacement: passo 7, imagem 1 %32 BMS Replacement Replacement: passo 7, imagem 2 %32
    • Remove the fiberglass sheeting from the pack
    Pergunte ao FixBot
    Comentar
  8. BMS Replacement Replacement, Remove the negative terminal: passo 8, imagem 1 %32 BMS Replacement Replacement, Remove the negative terminal: passo 8, imagem 2 %32
    • Remove the negative terminal
    • Cover the negative terminal with tape
    Pergunte ao FixBot
    Comentar
  9. BMS Replacement Replacement, Disconnect old BMS: passo 9, imagem 1 %32 BMS Replacement Replacement, Disconnect old BMS: passo 9, imagem 2 %32 BMS Replacement Replacement, Disconnect old BMS: passo 9, imagem 3 %32
    • Unplug the 4 connectors from the BMS. these will all be reused. do not cut.
    • Cut the large main negative cables from the BMS. There are 3-4 at each end of the BMS.
    Pergunte ao FixBot
    Comentar
  10. BMS Replacement Replacement, Cut switch light wire: passo 10, imagem 1 %32 BMS Replacement Replacement, Cut switch light wire: passo 10, imagem 2 %32
    • Cut the black switch light wire as close to the BMS as possible.
    • A connector is soldered to this in step 14
    Pergunte ao FixBot
    Comentar
  11. BMS Replacement Replacement, Remove old BMS: passo 11, imagem 1 %32 BMS Replacement Replacement, Remove old BMS: passo 11, imagem 2 %32 BMS Replacement Replacement, Remove old BMS: passo 11, imagem 3 %32
    • Fully remove old BMS
    • Desolder short wires from the main negative
    • Ensure all old solder locations are smooth
    Pergunte ao FixBot
    Comentar
  12. BMS Replacement Replacement, Prepare New BMS: passo 12, imagem 1 %32 BMS Replacement Replacement, Prepare New BMS: passo 12, imagem 2 %32 BMS Replacement Replacement, Prepare New BMS: passo 12, imagem 3 %32
    • Remove fibreglass from old BMS and install on New BMS
    • Locate new BMS as shown
    • Solder main Negatives as shown
    • The new BMS has all of the connections from one end only.
    Pergunte ao FixBot
    Comentar
  13. BMS Replacement Replacement: passo 13, imagem 1 %32 BMS Replacement Replacement: passo 13, imagem 2 %32
    • Only after soldering the main negative plug in the ballance, switch and temperature connections
    • Arrange as neatly as possible to avoid pinch points
    • Tape down to secure BMS in place
    Pergunte ao FixBot
    Comentar
  14. BMS Replacement Replacement, Switch light cable: passo 14, imagem 1 %32
    • The light for the switch is illuminated when the pack is turned.
    • Solder or crimp the eye terminal to the switch light wire that was cut in step 10
    Pergunte ao FixBot
    Comentar
  15. BMS Replacement Replacement, Cable Routing: passo 15, imagem 1 %32 BMS Replacement Replacement, Cable Routing: passo 15, imagem 2 %32 BMS Replacement Replacement, Cable Routing: passo 15, imagem 3 %32
    • The New BMS has different cable routing than the old one
    • Cut a slot in the fibreglass for the for the new BMS cables
    • Wrap the fiberglass sheets back around the BMS
    • Use duct of fiberglass tape close and seal the fiberglass sheets around the battery pack
    Pergunte ao FixBot
    Comentar
  16. BMS Replacement Replacement: passo 16, imagem 1 %32 BMS Replacement Replacement: passo 16, imagem 2 %32
    • Connect the main negative to the terminal on the battery case.
    • Correct order is Terminal - main negative lug - eyelet - bolt
    Pergunte ao FixBot
    Comentar
  17. BMS Replacement Replacement, Functionality check: passo 17, imagem 1 %32 BMS Replacement Replacement, Functionality check: passo 17, imagem 2 %32
    • Turn the switch on and off to check that the red light turns on and off.
    • Check the BMS app to ensure the all cells and connected to the ballance leads
    • Use ant BMS V2 app from the app store
    Pergunte ao FixBot
    Comentar
  18. BMS Replacement Replacement, Heat shrink the pack: passo 18, imagem 1 %32 BMS Replacement Replacement, Heat shrink the pack: passo 18, imagem 2 %32 BMS Replacement Replacement, Heat shrink the pack: passo 18, imagem 3 %32
    • Insert wisdom here.
    Pergunte ao FixBot
    Comentar
Conclusão
Mark Duyvesteyn
Membro desde: 02/11/26
1.269 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 70
