Ir para o conteúdo principal
BLU Tank II Keypad Replacement
O que você precisa
  1. BLU Tank II Keypad Replacement, Back Panel: passo 1, imagem 1 %32 BLU Tank II Keypad Replacement, Back Panel: passo 1, imagem 2 %32
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
    Pergunte ao FixBot
    Comentar
  2. BLU Tank II Keypad Replacement, Battery: passo 2, imagem 1 %32
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
    Pergunte ao FixBot
    Comentar
  3. BLU Tank II Keypad Replacement, Front Panel: passo 3, imagem 1 %32 BLU Tank II Keypad Replacement, Front Panel: passo 3, imagem 2 %32
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
    Pergunte ao FixBot
    Comentar
  4. BLU Tank II Keypad Replacement: passo 4, imagem 1 %32
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
    Pergunte ao FixBot
    Comentar
  5. BLU Tank II Keypad Replacement, Keypad: passo 5, imagem 1 %32 BLU Tank II Keypad Replacement, Keypad: passo 5, imagem 2 %32 BLU Tank II Keypad Replacement, Keypad: passo 5, imagem 3 %32
    • Once the front plate is separated from the outer lens plate, place your fingers on the backside of the keypad.
    • Peel the keypad out from the keyholes in the front plate.
    Pergunte ao FixBot
    Comentar
Conclusão
David Kelchner
Membro desde: 03/08/17
632 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 370
