Ir para o conteúdo principal
BLU Life XL Volume Control Buttons Replacement
O que você precisa
  1. BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, imagem 1 %32 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, imagem 2 %32 BLU Life XL Volume Control Buttons Replacement, Volume Control Buttons: passo 1, imagem 3 %32
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
    Pergunte ao FixBot
    Comentar
  2. BLU Life XL Volume Control Buttons Replacement: passo 2, imagem 1 %32 BLU Life XL Volume Control Buttons Replacement: passo 2, imagem 2 %32
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. BLU Life XL Volume Control Buttons Replacement: passo 3, imagem 1 %32 BLU Life XL Volume Control Buttons Replacement: passo 3, imagem 2 %32
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
    Pergunte ao FixBot
    Comentar
  4. BLU Life XL Volume Control Buttons Replacement: passo 4, imagem 1 %32 BLU Life XL Volume Control Buttons Replacement: passo 4, imagem 2 %32 BLU Life XL Volume Control Buttons Replacement: passo 4, imagem 3 %32
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
James Whitlow
Membro desde: 02/14/18
342 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 34
Ao todo: 638
