Ir para o conteúdo principal
BLU Life X8 Motherboard Replacement
O que você precisa
  1. BLU Life X8 Motherboard Replacement, Battery: passo 1, imagem 1 %32 BLU Life X8 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
    Pergunte ao FixBot
    Comentar
  2. BLU Life X8 Motherboard Replacement: passo 2, imagem 1 %32
    • Use your thumb to pry off the back panel once the gap is large enough.
    Pergunte ao FixBot
    Comentar
  3. BLU Life X8 Motherboard Replacement: passo 3, imagem 1 %32
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
    Pergunte ao FixBot
    Comentar
  4. BLU Life X8 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 BLU Life X8 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
    Pergunte ao FixBot
    Comentar
  5. BLU Life X8 Motherboard Replacement: passo 5, imagem 1 %32
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
    Pergunte ao FixBot
    Comentar
  6. BLU Life X8 Motherboard Replacement: passo 6, imagem 1 %32
    • Once all the clips have been released, lift the frame and set it aside.
    Pergunte ao FixBot
    Comentar
  7. BLU Life X8 Motherboard Replacement: passo 7, imagem 1 %32 BLU Life X8 Motherboard Replacement: passo 7, imagem 2 %32
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. BLU Life X8 Motherboard Replacement: passo 8, imagem 1 %32 BLU Life X8 Motherboard Replacement: passo 8, imagem 2 %32 BLU Life X8 Motherboard Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
    Pergunte ao FixBot
    Comentar
  9. BLU Life X8 Motherboard Replacement: passo 9, imagem 1 %32
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
    Pergunte ao FixBot
    Comentar
  10. BLU Life X8 Motherboard Replacement: passo 10, imagem 1 %32
    • Slowly lift the vibration motor away from the frame and peel up the tape.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team S1-G2, Nance Fall 2017 Membro de USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Membros
Autoria de 12 guias
1Comentário do guia
These steps sure was easy then i thought it would be.
Sweetie Tufele - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 41
Ao todo: 784
