Introdução
If your audio connection is intermittent or non functional, it may be time to replace the audio jack.
O que você precisa
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Remove the three 1.4 mm diameter screws anchoring the circuit board in place with a Phillips #00 head screw driver.
Quase terminado!
Conclusão
