Ir para o conteúdo principal
Azpen A740 Battery Replacement
O que você precisa
  1. Azpen A740 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: passo 2, imagem 1 %32 Azpen A740 Battery Replacement, Battery: passo 2, imagem 2 %32
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: passo 4, imagem 1 %32 Azpen A740 Battery Replacement: passo 4, imagem 2 %32
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
Conclusão
Maile Sinclair
Membro desde: 01/21/15
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 4-5, Brown Winter 2015 Membro de USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,604
