Ir para o conteúdo principal
Azpen A720 Touch Screen Replacement
O que você precisa
    1. Azpen A720 Touch Screen Replacement, Back Cover: passo 1, imagem 1 %32 Azpen A720 Touch Screen Replacement, Back Cover: passo 1, imagem 2 %32
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Pergunte ao FixBot
      Comentar
    2. Azpen A720 Touch Screen Replacement: passo 2, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 2, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 2, imagem 3 %32
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Pergunte ao FixBot
      Comentar
    3. Azpen A720 Touch Screen Replacement: passo 3, imagem 1 %32
      • Remove the rear casing.
      Pergunte ao FixBot
      Comentar
    1. Azpen A720 Touch Screen Replacement, Touch Screen: passo 4, imagem 1 %32 Azpen A720 Touch Screen Replacement, Touch Screen: passo 4, imagem 2 %32 Azpen A720 Touch Screen Replacement, Touch Screen: passo 4, imagem 3 %32
      • Use the plastic opening tool to gently lift the release lever for the ZIF cable.
      • The ZIF connector is delicate. Be careful not to damage the tab!
      Pergunte ao FixBot
      Comentar
    2. Azpen A720 Touch Screen Replacement: passo 5, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 5, imagem 2 %32
      • Gently remove the ZIF cable from the connector.
      Pergunte ao FixBot
      Comentar
    3. Azpen A720 Touch Screen Replacement: passo 6, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 6, imagem 2 %32
      • Disconnect the second ZIF connector using the same method detailed earlier.
      Pergunte ao FixBot
      Comentar
    4. Azpen A720 Touch Screen Replacement: passo 7, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 7, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 7, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Locate the microphone. It is at the top of the device and next to the audio jack.
      • Using tweezers, gently remove the microphone.
      • Remember to reinsert the microphone when reassembling!
      Pergunte ao FixBot
      Comentar
    5. Azpen A720 Touch Screen Replacement: passo 8, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 8, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 8, imagem 3 %32
      • Remove the three 4mm Phillips #00 screws securing the motherboard in place.
      Pergunte ao FixBot
      Comentar
    6. Azpen A720 Touch Screen Replacement: passo 9, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 9, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 9, imagem 3 %32
      • Remove the motherboard from the casing, being careful not to damage the remaining wires.
      • It's okay if the buttons fall out of the case.
      • Flip the motherboard so it rests upside down and out of the way of the metal backing.
      Pergunte ao FixBot
      Comentar
    7. Azpen A720 Touch Screen Replacement: passo 10, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 10, imagem 2 %32
      • Starting at the edge, use a plastic opening tool to carefully pry the front casing off of the metal backing.
      • Leave the plastic opening tool in place underneath the metal backing to prop it up.
      • Move the motherboard out of the way as needed.
      Pergunte ao FixBot
      Comentar
    8. Azpen A720 Touch Screen Replacement: passo 11, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 11, imagem 2 %32
      • Using a second plastic opening tool, pry the adjacent side of the metal backing from the front casing/touch screen.
      • Pry close to the plastic tabs so you do not break them.
      Pergunte ao FixBot
      Comentar
    9. Azpen A720 Touch Screen Replacement: passo 12, imagem 1 %32
      • Remove the first plastic opening tool and use it to pry along the second edge.
      • Slide the tool along the edge until it is close the next tab, and gently pry the metal up.
      Pergunte ao FixBot
      Comentar
    10. Azpen A720 Touch Screen Replacement: passo 13, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 13, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 13, imagem 3 %32
      • Use a third plastic opening tool to pry at the corner of the tablet and pop off the metal backing.
      Pergunte ao FixBot
      Comentar
    11. Azpen A720 Touch Screen Replacement: passo 14, imagem 1 %32 Azpen A720 Touch Screen Replacement: passo 14, imagem 2 %32 Azpen A720 Touch Screen Replacement: passo 14, imagem 3 %32
      • Lift the metal backing from the propped edge to remove it from the front casing.
      • Replace the broken front touch screen and casing with a new one.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Anna
Membro desde: 03/17/15
353 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 3,094
