Ir para o conteúdo principal
Azpen A720 Battery Replacement
O que você precisa
  1. Azpen A720 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Azpen A720 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
    Pergunte ao FixBot
  2. Azpen A720 Battery Replacement: passo 2, imagem 1 %32 Azpen A720 Battery Replacement: passo 2, imagem 2 %32 Azpen A720 Battery Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
    Pergunte ao FixBot
  3. Azpen A720 Battery Replacement: passo 3, imagem 1 %32
    • Remove the rear casing.
    Pergunte ao FixBot
  4. Azpen A720 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Locate the batteries' connection points.
    Pergunte ao FixBot
  5. Azpen A720 Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
    Pergunte ao FixBot
  6. Azpen A720 Battery Replacement: passo 6, imagem 1 %32 Azpen A720 Battery Replacement: passo 6, imagem 2 %32
    • Peel the black sticker off the battery to disconnect the wifi antennae.
    Pergunte ao FixBot
  7. Azpen A720 Battery Replacement: passo 7, imagem 1 %32 Azpen A720 Battery Replacement: passo 7, imagem 2 %32 Azpen A720 Battery Replacement: passo 7, imagem 3 %32
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
    Pergunte ao FixBot
  8. Azpen A720 Battery Replacement: passo 8, imagem 1 %32 Azpen A720 Battery Replacement: passo 8, imagem 2 %32
    • Remove the old battery and replace it with the new battery.
    Pergunte ao FixBot
Linha de Chegada
Uma outra pessoa concluiu este guia.
Ben
Membro desde: 03/18/15
280 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 50
Ao todo: 2,570
