Ir para o conteúdo principal
Azpen A701 Motherboard Replacement
O que você precisa
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: passo 1, imagem 1 %32
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: passo 2, imagem 1 %32 Azpen A701 Motherboard Replacement: passo 2, imagem 2 %32
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: passo 4, imagem 1 %32
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Azpen A701 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Azpen A701 Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: passo 6, imagem 1 %32 Azpen A701 Motherboard Replacement: passo 6, imagem 2 %32 Azpen A701 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: passo 11, imagem 1 %32
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: passo 12, imagem 1 %32
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Conclusão
Michael
Membro desde: 03/11/15
568 Reputação
Autoria de 4 guias
Equipe
Colorado Springs, Team 2-1, Panko Spring 2015 Membro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 331
