Ir para o conteúdo principal
Azpen A701 Battery Replacement
O que você precisa
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: passo 1, imagem 1 %32
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: passo 2, imagem 1 %32 Azpen A701 Battery Replacement: passo 2, imagem 2 %32
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: passo 3, imagem 1 %32
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: passo 4, imagem 1 %32
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: passo 6, imagem 1 %32
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Conclusão
Grant Harding
Membro desde: 03/11/15
249 Reputação
Autoria de 2 guias
Equipe
Colorado Springs, Team 2-1, Panko Spring 2015 Membro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 719
