Ir para o conteúdo principal
Axess TA2513-10WT Battery Replacement
O que você precisa
  1. Axess TA2513-10WT Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
    Pergunte ao FixBot
    Comentar
  2. Axess TA2513-10WT Battery Replacement: passo 2, imagem 1 %32 Axess TA2513-10WT Battery Replacement: passo 2, imagem 2 %32 Axess TA2513-10WT Battery Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
    Pergunte ao FixBot
    Comentar
  3. Axess TA2513-10WT Battery Replacement: passo 3, imagem 1 %32
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
    Pergunte ao FixBot
    Comentar
  4. Axess TA2513-10WT Battery Replacement: passo 4, imagem 1 %32
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
    Pergunte ao FixBot
    Comentar
  5. Axess TA2513-10WT Battery Replacement, Battery: passo 5, imagem 1 %32
    • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
    Pergunte ao FixBot
    Comentar
  6. Axess TA2513-10WT Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery up with your hands to ensure complete detachment from the screen.
    Pergunte ao FixBot
    Comentar
  7. Axess TA2513-10WT Battery Replacement: passo 7, imagem 1 %32
    • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
    Pergunte ao FixBot
    Comentar
  8. Axess TA2513-10WT Battery Replacement: passo 8, imagem 1 %32
    • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
    Pergunte ao FixBot
    Comentar
  9. Axess TA2513-10WT Battery Replacement: passo 9, imagem 1 %32
    • Remove the red wire from the node labeled "B+"
    Pergunte ao FixBot
    Comentar
  10. Axess TA2513-10WT Battery Replacement: passo 10, imagem 1 %32
    • Using the same process as the red wire, detach the black wire from the node labeled "B-".
    Pergunte ao FixBot
    Comentar
  11. Axess TA2513-10WT Battery Replacement: passo 11, imagem 1 %32
    • The battery should now be separated from both the screen and circuit board
    Pergunte ao FixBot
    Comentar
Conclusão
Steven Kavanagh
Membro desde: 03/24/15
301 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 6-3, Shaver Spring 2015 Membro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 645
