Introdução
Replacing the battery in the Tommy 20 is a relatively simple replacement, just make sure you have 3 replacement AA batteries ready to go beforehand along with a Phillips #1 Screwdriver! A good first step in any repair goal concerning the Tommy 20!
O que você precisa
Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver.
Lift the cover away from the gun and remove.
Remove all three batteries from compartment by pulling up on the positive end of each battery.
Uma outra pessoa concluiu este guia.
