Ir para o conteúdo principal
August Smart Lock Gear Replacement
O que você precisa
  1. August Smart Lock Gear Replacement, Gear: passo 1, imagem 1 %32 August Smart Lock Gear Replacement, Gear: passo 1, imagem 2 %32 August Smart Lock Gear Replacement, Gear: passo 1, imagem 3 %32
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  2. August Smart Lock Gear Replacement: passo 2, imagem 1 %32 August Smart Lock Gear Replacement: passo 2, imagem 2 %32 August Smart Lock Gear Replacement: passo 2, imagem 3 %32
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
William Fink
Membro desde: 09/26/17
841 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Membros
Autoria de 3 guias
8Comentários do guia
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Responder Compartilhar
Any tips on where to get replacement gears?
Byron H - Responder Compartilhar
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Responder Compartilhar
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Responder Compartilhar
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 68
Ao todo: 13,991
