Ir para o conteúdo principal
August Smart Lock Accelerometer Replacement
O que você precisa
  1. August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, imagem 1 %32 August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, imagem 2 %32 August Smart Lock Accelerometer Replacement, Accelerometer: passo 1, imagem 3 %32
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
    Pergunte ao FixBot
    Comentar
  2. August Smart Lock Accelerometer Replacement: passo 2, imagem 1 %32 August Smart Lock Accelerometer Replacement: passo 2, imagem 2 %32 August Smart Lock Accelerometer Replacement: passo 2, imagem 3 %32
    • Grab the gears and lift them up to remove from the device
    Pergunte ao FixBot
    Comentar
  3. August Smart Lock Accelerometer Replacement: passo 3, imagem 1 %32 August Smart Lock Accelerometer Replacement: passo 3, imagem 2 %32 August Smart Lock Accelerometer Replacement: passo 3, imagem 3 %32
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
    Pergunte ao FixBot
    Comentar
  4. August Smart Lock Accelerometer Replacement: passo 4, imagem 1 %32
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
    Pergunte ao FixBot
    Comentar
  5. August Smart Lock Accelerometer Replacement: passo 5, imagem 1 %32 August Smart Lock Accelerometer Replacement: passo 5, imagem 2 %32
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
William Fink
Membro desde: 09/26/17
841 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Membros
Autoria de 3 guias
7Comentários do guia
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Responder Compartilhar
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Responder Compartilhar
Same as above…. where to locate an accelerometer??
osallabe - Responder Compartilhar
Did anyone find out where to buy the part?
LBurd - Responder Compartilhar
Where can I find one
Jeff Wasilewski - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 57
Ao todo: 8,817
