Introdução
This guide will help your install a new driver.
O que você precisa
With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Como soldar e dessoldar contatos.
2 comentários
where can i buy a replacement driver?
You can order parts directly from PARTS@ATUS.COM
