Ir para o conteúdo principal
Audio Technica ATH-AD500 Driver Replacement
O que você precisa
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: passo 1, imagem 1 %32
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: passo 2, imagem 1 %32
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: passo 3, imagem 1 %32
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: passo 4, imagem 1 %32
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: passo 5, imagem 1 %32
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: passo 6, imagem 1 %32 Audio Technica ATH-AD500 Driver Replacement: passo 6, imagem 2 %32
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Como soldar e dessoldar contatos.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: passo 7, imagem 1 %32 Audio Technica ATH-AD500 Driver Replacement: passo 7, imagem 2 %32
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
Conclusão
Nick Levy
Membro desde: 01/13/13
177 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-19, Forte Winter 2013 Membro de Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
Membros da 6
Autoria de 17 guias
2 comentários
where can i buy a replacement driver?
acidxgangster - Responder
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 10,950
