Ir para o conteúdo principal
AuKing M8-F Bulb Replacement
O que você precisa
  1. AuKing M8-F Bulb Replacement, Motherboard: passo 1, imagem 1 %32 AuKing M8-F Bulb Replacement, Motherboard: passo 1, imagem 2 %32
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. AuKing M8-F Bulb Replacement: passo 2, imagem 1 %32 AuKing M8-F Bulb Replacement: passo 2, imagem 2 %32 AuKing M8-F Bulb Replacement: passo 2, imagem 3 %32
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
  3. AuKing M8-F Bulb Replacement: passo 3, imagem 1 %32 AuKing M8-F Bulb Replacement: passo 3, imagem 2 %32 AuKing M8-F Bulb Replacement: passo 3, imagem 3 %32
    • Flip up the black locking flaps then remove the two ribbon cables.
  4. AuKing M8-F Bulb Replacement: passo 4, imagem 1 %32 AuKing M8-F Bulb Replacement: passo 4, imagem 2 %32
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
  5. AuKing M8-F Bulb Replacement: passo 5, imagem 1 %32 AuKing M8-F Bulb Replacement: passo 5, imagem 2 %32
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
  6. AuKing M8-F Bulb Replacement, Bulb: passo 6, imagem 1 %32 AuKing M8-F Bulb Replacement, Bulb: passo 6, imagem 2 %32
    • Remove the six 9 mm screws using a Phillips #0 screwdriver to detach both of the black panels.
  7. AuKing M8-F Bulb Replacement: passo 7, imagem 1 %32 AuKing M8-F Bulb Replacement: passo 7, imagem 2 %32 AuKing M8-F Bulb Replacement: passo 7, imagem 3 %32
    • Slide the motherboard upwards to remove the wire component connected to the LED bulb.
    • Gently remove the LED bulb and the attached heatsink from the projector
Conclusão
Aubrey Haynes
Membro desde: 09/13/23
277 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 63
Duração total: 379
