Ir para o conteúdo principal
Atari Lynx Backlight Replacement
O que você precisa
  1. Atari Lynx Backlight Replacement, Atari Lynx: passo 1, imagem 1 %32
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Backlight Replacement: passo 2, imagem 1 %32
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Backlight Replacement: passo 3, imagem 1 %32
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Backlight Replacement: passo 4, imagem 1 %32
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Backlight Replacement, Backlight: passo 5, imagem 1 %32
    • Pull out the logic-board.
    • Pull to the sides the four rubber tabs holding in the screen
  6. Atari Lynx Backlight Replacement: passo 6, imagem 1 %32
    • Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
  7. Atari Lynx Backlight Replacement: passo 7, imagem 1 %32
    • Flip over the motherboard and remove the shield behind the backlight.
  8. Atari Lynx Backlight Replacement: passo 8, imagem 1 %32 Atari Lynx Backlight Replacement: passo 8, imagem 2 %32
    • Flip the motherboard back over and desolder the two components that are holding the backlight in place.
    • If you need help with basic desoldering, click here.
Conclusão
3 outras pessoas executaram este guia.
John Lopez
Membro desde: 01/27/14
443 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-42, Maness Winter 2014 Membro de Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Duração total: 4,454
