Ir para o conteúdo principal
Atari Flashback 6 Controller Board Repair
O que você precisa
  1. Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, imagem 1 %32 Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, imagem 2 %32 Atari Flashback 6 Controller Board Repair, Atari Flashback 6 Controller Board Repair: passo 1, imagem 3 %32
    • If the controller currently contains batteries, please remove them before starting the repair.
    • Use a Phillips #1 screwdriver to remove single 1.5 mm-long screw securing the battery cover.
    • Lift the battery cover off.
    • Depress the spring that is in contact with the negative side of the battery to remove the batteries. Push down, and then remove batteries one at a time.
  2. Atari Flashback 6 Controller Board Repair: passo 2, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 2, imagem 2 %32 Atari Flashback 6 Controller Board Repair: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four 2 mm screws from the bottom of the Atari controller.
  3. Atari Flashback 6 Controller Board Repair: passo 3, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 3, imagem 2 %32
    • Open the bottom case gently.
    • Do not rip it open as it is connected by a ribbon cable to the top case.
    • Remove the single 2 mm-long Phillips #1 screw securing the motherboard to the top case.
    • Use a spudger to gently remove the motherboard from the top case.
    • Be careful to avoid bending the board or the LED light.
  4. Atari Flashback 6 Controller Board Repair: passo 4, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 4, imagem 2 %32 Atari Flashback 6 Controller Board Repair: passo 4, imagem 3 %32
    • Separate the button board from the back panel.
    • Like a car battery, the negative terminal attaches to the black wire and the positive with the red wire.
    • You may have to strip the wires to expose the internal copper wiring.
    • Use a wire stripper to expose the internal wiring to secure a proper connection in the next step.
  5. Atari Flashback 6 Controller Board Repair: passo 5, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 5, imagem 2 %32
    • Using a soldering iron can be dangerous. Because of the high temperature, please be sure to exercise caution when using this tool.
    • Attach the red wire to the positive terminal using the soldering iron, melting the solder to create a connection.
    • Attach the black wire to the negative terminal using the soldering iron, melting the solder to create a connection.
  6. Atari Flashback 6 Controller Board Repair: passo 6, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 6, imagem 2 %32
    • Use a Phillips #1 screwdriver to replace the 2 mm screw that secures the motherboard to the top case.
    • Make sure to not pull on wires that are now attached.
  7. Atari Flashback 6 Controller Board Repair: passo 7, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 7, imagem 2 %32
    • Reinsert the front panel into the groove of the outer shell.
  8. Atari Flashback 6 Controller Board Repair: passo 8, imagem 1 %32 Atari Flashback 6 Controller Board Repair: passo 8, imagem 2 %32
    • Replace the 2 mm Phillips #1 screws in the back panel to reassemble the controller.
    • After the back panel is secure, re-install the batteries, and replace the 1.5 mm Phillips #1 screw.
  9. Atari Flashback 6 Controller Board Repair: passo 9, imagem 1 %32
    • Make sure to test the product by playing an Atari game. If buttons or directional toggle are not working, repeat steps 1- 8.
Conclusão
Ensure you test your controller when finished to verify the proper connection.
Kyle Albright
Membro desde: 02/26/24
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 46
