Ir para o conteúdo principal
Atari Flashback 2 Reset and Select Button Replacement
O que você precisa
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 1 %32 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 2 %32 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 3 %32
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
    Pergunte ao FixBot
    Comentar
  2. Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 1 %32 Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 2 %32 Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 3 %32
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
2Comentários do guia
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Responder Compartilhar
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 58
Ao todo: 1,402
