Ir para o conteúdo principal
Atari Flashback 2 Console Power Button Replacement
O que você precisa
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, imagem 1 %32 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, imagem 2 %32 Atari Flashback 2 Console Power Button Replacement, Console Power Button: passo 1, imagem 3 %32
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
    Pergunte ao FixBot
    Comentar
  2. Atari Flashback 2 Console Power Button Replacement: passo 2, imagem 1 %32 Atari Flashback 2 Console Power Button Replacement: passo 2, imagem 2 %32 Atari Flashback 2 Console Power Button Replacement: passo 2, imagem 3 %32
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
Faith Julian
Membro desde: 09/18/18
205 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 1,462
