Ir para o conteúdo principal
Atari 5200 Motherboard Cleaning
O que você precisa
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: passo 1, imagem 1 %32
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: passo 2, imagem 1 %32
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: passo 3, imagem 1 %32
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Conclusão
Uma outra pessoa concluiu este guia.
Zach Petryszyn
Membro desde: 09/26/14
21 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
Membros da 5
Autoria de 17 guias
Um comentário
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 2,639
