Ir para o conteúdo principal
Asus Zenfone 3 Max Motherboard Replacement
O que você precisa
  1. Asus Zenfone 3 Max Motherboard Replacement, SIM card: passo 1, imagem 1 %32
    • Locate the SIM card slot on the upper left side of your Asus Zenfone Max 3.
  2. Asus Zenfone 3 Max Motherboard Replacement: passo 2, imagem 1 %32
    • Use the iFixit 150mm Flex Extension with the Hex 0.7 bit or the SIM card eject tool.
    • Stick the tool into the hole on the SIM card slot and open the slot with it.
  3. Asus Zenfone 3 Max Motherboard Replacement: passo 3, imagem 1 %32
    • Pull out the old SIM card all the way so it is no longer in the phone.
  4. Asus Zenfone 3 Max Motherboard Replacement, Back cover: passo 4, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement, Back cover: passo 4, imagem 2 %32
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  5. Asus Zenfone 3 Max Motherboard Replacement: passo 5, imagem 1 %32
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  6. Asus Zenfone 3 Max Motherboard Replacement, Battery: passo 6, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement, Battery: passo 6, imagem 2 %32 Asus Zenfone 3 Max Motherboard Replacement, Battery: passo 6, imagem 3 %32
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  7. Asus Zenfone 3 Max Motherboard Replacement: passo 7, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement: passo 7, imagem 2 %32 Asus Zenfone 3 Max Motherboard Replacement: passo 7, imagem 3 %32
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
  8. Asus Zenfone 3 Max Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement, Motherboard: passo 8, imagem 2 %32
    • Remove the two 2.5mm Phillips #0 screws located in the upper corners of the device indicated with red circles.
    • After both screws have been removed, detach the white plastic internal panel completely from the device.
  9. Asus Zenfone 3 Max Motherboard Replacement: passo 9, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement: passo 9, imagem 2 %32 Asus Zenfone 3 Max Motherboard Replacement: passo 9, imagem 3 %32
    • Next, remove the four 2.5mm Phillips #0 screws surrounding the motherboard component.
    • Following the removal of all four screws, carefully detach the two device cables at the bottom of the motherboard component using the nylon spudger.
    • Next, disconnect the remaining component cable using the same technique described in the previous step.
    • Metal spudgers should not be used on internal components, they are not ESD safe.
  10. Asus Zenfone 3 Max Motherboard Replacement: passo 10, imagem 1 %32 Asus Zenfone 3 Max Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully grip the motherboard and gently lift and remove it from the internal device casing.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Duração total: 1,339
