Ir para o conteúdo principal
Asus Zenbook UX550GE-XB71T Battery Replacement
O que você precisa
  1. Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: passo 1, imagem 1 %32 Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn computer off and disconnect it from power.
    • Flip it over so the backside is facing you.
  2. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 2, imagem 1 %32 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 2, imagem 2 %32
    • Using the T5 Torx screwdriver, remove the ten screws under the computer.
    • Gently remove the back cover from the device.
  3. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 3, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four screws along the battery.
  4. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, imagem 1 %32 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, imagem 2 %32 Asus Zenbook UX550GE-XB71T Battery Replacement: passo 4, imagem 3 %32
    • Disconnect the ribbon cable by pushing upwards on the ZIF connector.
  5. Asus Zenbook UX550GE-XB71T Battery Replacement: passo 5, imagem 1 %32
    • Disconnect and remove the battery from the device.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 55
Ao todo: 1,414
