Ir para o conteúdo principal
Asus Zenbook UX32VD RAM Replacement
O que você precisa
  1. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, imagem 1 %32 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, imagem 2 %32 Asus Zenbook UX32VD RAM Replacement, Bottom Panel: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    T5 Torx Screwdriver
    $9.99
    Pergunte ao FixBot
    Comentar
  2. Asus Zenbook UX32VD RAM Replacement: passo 2, imagem 1 %32 Asus Zenbook UX32VD RAM Replacement: passo 2, imagem 2 %32 Asus Zenbook UX32VD RAM Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
    Pergunte ao FixBot
    Comentar
  3. Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, imagem 1 %32 Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, imagem 2 %32 Asus Zenbook UX32VD RAM Replacement, RAM: passo 3, imagem 3 %32
    • Push away the RAM retaining arms from the RAM chip.
    • The RAM chip will spring up once the retaining arms are pushed away from the chip.
    • Remove the RAM chip completely.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Paola
Membro desde: 09/17/15
270 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Membros
Autoria de 6 guias
2Comentários do guia
Replaced the 4 GB RAM module in my UX32VD with an 8 GB Timetec Hynix IC DDR3 1600MHz PC3-12800 Non ECC Unbuffered 1.35V CL11 2Rx8 Dual Rank 204 Pin SODIMM Laptop Notebook Computer Memory Ram Module using this guide. It worked like a charm. Thank you for posting the guide!
Le Zap - Responder Compartilhar
Worked like a charm on a UX32VD. Installed a "Kingston SO-DDR3L-RAM ValueRAM 1600 MHz 1x 8 GB" in 3min
HUGE DIFFERENCE
Thank you very much!
PS. There was a foil wrapper around the old RAM that I removed and put around the new RAM. Heat dissipation I imagine
Valentin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 17
Últimos 30 dias: 56
Ao todo: 5,193
