Ir para o conteúdo principal
Asus Zenbook UX303L Hard Drive Replacement
O que você precisa
  1. Asus Zenbook UX303L Hard Drive Replacement, SSD: passo 1, imagem 1 %32
    • Make sure the device is turned off and disconnected from the battery charger.
    i want to replace hdd with ssd on my UX303UB
    can this guide help me ?
    aliirezaaa - Responder
    On the UX303L Model, there are 2 additional screws on the bottom panel under the rear 2 rubber standoffs. If you are having issues opening the bottom after removing the 9 screws mentioned, that is the reason.
    Patrick Morgan - Responder
  2. Asus Zenbook UX303L Hard Drive Replacement: passo 2, imagem 1 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 2, imagem 2 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Remove two additional screws, if present, from beneath the rubber pads. (Pry up each rubber pad to access its screw.)
    • Carefully remove the bottom cover. The cover doesn't just lift up, you have to lift it to a approx. 45° angle, then pull towards the exterior (there are two small plastic claws that maintain the cover attached)
  3. Asus Zenbook UX303L Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the five screws attaching the battery pack by using a PH-1 screwdriver.
  4. Asus Zenbook UX303L Hard Drive Replacement: passo 4, imagem 1 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Unhook the black, red, and white switch using the tweezers.
  5. Asus Zenbook UX303L Hard Drive Replacement: passo 5, imagem 1 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 5, imagem 2 %32
    • Detach the positive and negative black, white, yellow, and red switch with the use of tweezers.
  6. Asus Zenbook UX303L Hard Drive Replacement: passo 6, imagem 1 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 6, imagem 2 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 6, imagem 3 %32
    • Unhook the black and white coiled wire using the tweezers.
  7. Asus Zenbook UX303L Hard Drive Replacement: passo 7, imagem 1 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 7, imagem 2 %32 Asus Zenbook UX303L Hard Drive Replacement: passo 7, imagem 3 %32
    • Remove the 3 screws surrounding the hard drive using the PH-1 screwdriver.
    • Gently lift and detach the hard drive, and pull it out.
    • If your model has never been opened, you might have this "cushion sticker" that makes it difficult to unplug the hard drive. You can just peel it and put it back later.
Conclusão
21 outras pessoas executaram este guia.
Cindy Lopez
Membro desde: 10/13/15
648 Reputação
Autoria de 1 guia
Equipe
4Comentários do guia
This guide worked fine for me. I have two suggestions that made my disassembly easier.
First, I used the standard blue guitar pick to gently pop the back cover off near the hinge. Nothing special here.
Second, the power connector in Step 5 lifts up to disconnect. I found using the blue pry bar to lift the side of the connector much easier than tweezers.
Good, clear, complete guide.
Greg - Responder
Great guide, worked for me.
I second Greg’s comment: Step 5’s battery connector lifts up, so using something like iFixit’s blue pry bar might be easier.
Additionally, for Step 7, the 3 screws might be hidden under cushion stickers. These can be peeled off and put back later.
Chawit Leosrisook - Responder
Mein Laptop geht nach dem Umbau nicht mehr einzuschalten. Selbst die kleine Akku LED leuchtet nicht mehr, sobald das Netzkabel dran gesteckt ist. :(
Steff - Responder
I have the same issue. After putting everything back together, there is no charging light when the power cable is connect. Also nothing happens when pressing the power button.
I tried removing the battery and the CMOS battery, holding the power button for 30-40 seconds before re-assemblingt the device. But that did not help.
Felix -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 101
Ao todo: 36,440
